Ana içeriğe geç
Dell Latitude E7450 CMOS battery Replacement
Neye ihtiyacın var
    • Before performing this task, make sure you turn off the computer and disconnect everything from it.
    • Remove the battery from the computer by sliding the release latch.
    • Remove the computer cover by unscrewing the two screws highlighted in the picture.
    • Disconnect the CMOS battery from its connector and remove from the system board.
    • Replace the battery by plugging the connector to the board and placing the battery in the correct position.
    • If you want to reset the BIOS, press and hold the power button for 10-20 seconds to drain residual power.
Sonuç
If you are trying to reset the BIOS Admin Password, I would recommend this tutorial :)
https://www.youtube.com/watch?v=9LugtKgf...
Brandon
85 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 300
