Ana içeriğe geç
Dell Latitude E7470 Battery Replacement
Neye ihtiyacın var
  1. Dell Latitude E7470 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
  2. Dell Latitude E7470 Battery Replacement, Battery: adım 2, 1 resimden 1.
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470 Battery Replacement: adım 3, 2 resimden 1. Dell Latitude E7470 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the laptop.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 29
Son 30 gün: 180
Her zaman: 10,397
