Ana içeriğe geç
Dell Latitude E7470 Fan and Heatsink Replacement
Neye ihtiyacın var
  1. Dell Latitude E7470 Fan and Heatsink Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
  2. Dell Latitude E7470 Fan and Heatsink Replacement, Battery: adım 2, 1 resimden 1.
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470 Fan and Heatsink Replacement: adım 3, 2 resimden 1. Dell Latitude E7470 Fan and Heatsink Replacement: adım 3, 2 resimden 2.
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470 Fan and Heatsink Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the laptop.
  5. Dell Latitude E7470 Fan and Heatsink Replacement, Fan and Heatsink: adım 5, 2 resimden 1. Dell Latitude E7470 Fan and Heatsink Replacement, Fan and Heatsink: adım 5, 2 resimden 2.
    • After opening the backcase of the computer, remove the screws using the Phillips #0 screwdriver.
    • Unplug and remove the wire from the socket.
  6. Dell Latitude E7470 Fan and Heatsink Replacement: adım 6, 1 resimden 1.
    • Remove the fan and heatsink from the laptop.
    • Make sure to wipe off the existing thermal paste from the CPU and heatsink with an alcohol-soaked pad and apply a new layer.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 42
Her zaman: 2,682
