Ana içeriğe geç
Dell Latitude E7470 Network Card Replacement
Neye ihtiyacın var
  1. Dell Latitude E7470 Network Card Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
  2. Dell Latitude E7470 Network Card Replacement, Battery: adım 2, 1 resimden 1.
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470 Network Card Replacement: adım 3, 2 resimden 1. Dell Latitude E7470 Network Card Replacement: adım 3, 2 resimden 2.
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470 Network Card Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the laptop.
  5. Dell Latitude E7470 Network Card Replacement, Network Card: adım 5, 2 resimden 1. Dell Latitude E7470 Network Card Replacement, Network Card: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Halberd Spudger
    $2.99
    Satın Al
    • Use a halberd spudger and your fingers to detach two wires from the Wi-Fi card.
  6. Dell Latitude E7470 Network Card Replacement: adım 6, 1 resimden 1.
    • Remove the single screw from the Wi-Fi card using a Phillips #0 screwdriver.
  7. Dell Latitude E7470 Network Card Replacement: adım 7, 1 resimden 1.
    • Use an iFixit opening tool and your fingers to pull the Wi-Fi card out of its socket.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 673
