Ana içeriğe geç
Dell Latitude ST Motherboard Replacement
Neye ihtiyacın var
  1. Dell Latitude ST Motherboard Replacement, Battery: adım 1, 3 resimden 1. Dell Latitude ST Motherboard Replacement, Battery: adım 1, 3 resimden 2. Dell Latitude ST Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the back panel tab.
    • Press down on the tab to remove the panel.
  2. Dell Latitude ST Motherboard Replacement: adım 2, 3 resimden 1. Dell Latitude ST Motherboard Replacement: adım 2, 3 resimden 2. Dell Latitude ST Motherboard Replacement: adım 2, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove the four 6mm screws attaching the inside panel to the device.
  3. Dell Latitude ST Motherboard Replacement: adım 3, 3 resimden 1. Dell Latitude ST Motherboard Replacement: adım 3, 3 resimden 2. Dell Latitude ST Motherboard Replacement: adım 3, 3 resimden 3.
    • Use the blue plastic opening tool to push in the tab located on the backside of the device.
    • Slide the tool around the edges of the device to unsnap the tabs and pry the frame off.
  4. Dell Latitude ST Motherboard Replacement: adım 4, 3 resimden 1. Dell Latitude ST Motherboard Replacement: adım 4, 3 resimden 2. Dell Latitude ST Motherboard Replacement: adım 4, 3 resimden 3.
    • Remove the three 6mm Phillips #0 screws attaching the battery.
  5. Dell Latitude ST Motherboard Replacement: adım 5, 3 resimden 1. Dell Latitude ST Motherboard Replacement: adım 5, 3 resimden 2. Dell Latitude ST Motherboard Replacement: adım 5, 3 resimden 3.
    • Using your hands or a plastic opening tool, unplug the white battery cable.
    • Push forward on the top part of the cable to disconnect it from the device.
  6. Dell Latitude ST Motherboard Replacement: adım 6, 3 resimden 1. Dell Latitude ST Motherboard Replacement: adım 6, 3 resimden 2. Dell Latitude ST Motherboard Replacement: adım 6, 3 resimden 3.
    • Pull up on the black tab located at the top of the battery to remove the battery from the device.
  7. Dell Latitude ST Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. Dell Latitude ST Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Remove the 3mm Phillips #0 screw from the SSD drive which is located above the speaker and to the left of the motherboard.
  8. Dell Latitude ST Motherboard Replacement: adım 8, 3 resimden 1. Dell Latitude ST Motherboard Replacement: adım 8, 3 resimden 2. Dell Latitude ST Motherboard Replacement: adım 8, 3 resimden 3.
    • Pull up on the white and black cables attached to the WLAN to unplug them.
    • Remove the one 3mm the Phillips #0 screw attached to the WLAN card.
    • Remove the WLAN card.
  9. Dell Latitude ST Motherboard Replacement: adım 9, 3 resimden 1. Dell Latitude ST Motherboard Replacement: adım 9, 3 resimden 2. Dell Latitude ST Motherboard Replacement: adım 9, 3 resimden 3.
    • Pull up on the copper tape to loosen it from the screen.
    • Unscrew the seven 6mm the Phillips #0 screws from the base.
  10. Dell Latitude ST Motherboard Replacement: adım 10, 2 resimden 1. Dell Latitude ST Motherboard Replacement: adım 10, 2 resimden 2.
    • Locate the grey LCD cable attached to the motherboad on the device.
    • Pull up the black tape handle attached to the LCD cable to disconnect it.
  11. Dell Latitude ST Motherboard Replacement: adım 11, 3 resimden 1. Dell Latitude ST Motherboard Replacement: adım 11, 3 resimden 2. Dell Latitude ST Motherboard Replacement: adım 11, 3 resimden 3.
    • Using your hands or the blue plastic opening tool, go along the edges of the frame and unsnap the screen from the middle frame.
  12. Dell Latitude ST Motherboard Replacement: adım 12, 3 resimden 1. Dell Latitude ST Motherboard Replacement: adım 12, 3 resimden 2. Dell Latitude ST Motherboard Replacement: adım 12, 3 resimden 3.
    • Turn over the middle frame.
    • Pull on the white cables with the blue tape to disconnect them.
  13. Dell Latitude ST Motherboard Replacement: adım 13, 2 resimden 1. Dell Latitude ST Motherboard Replacement: adım 13, 2 resimden 2.
    • Flip the middle frame back over.
    • Unplug the three white cables attached to the motherboard.
    • Use the blue plastic opening tool to push down on the cables to disconnect them.
  14. Dell Latitude ST Motherboard Replacement: adım 14, 3 resimden 1. Dell Latitude ST Motherboard Replacement: adım 14, 3 resimden 2. Dell Latitude ST Motherboard Replacement: adım 14, 3 resimden 3.
    • Unplug the last motherboard cable attached to the bottom of the frame and the motherboard.
    • With the blue plastic opening tool, flip up the white latch on the top part of the cable.
    • Pull up on the cable using the blue plastic opening tool to disconnect it from the motherboard.
  15. Dell Latitude ST Motherboard Replacement: adım 15, 3 resimden 1. Dell Latitude ST Motherboard Replacement: adım 15, 3 resimden 2. Dell Latitude ST Motherboard Replacement: adım 15, 3 resimden 3.
    • Remove the single 6mm screw attaching the motherboard.
    • Remove the Motherboard from the middle frame of the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 635
