Ana içeriğe geç
Dell Latitude ST Screen Replacement
Neye ihtiyacın var
  1. Dell Latitude ST Screen Replacement, Battery: adım 1, 3 resimden 1. Dell Latitude ST Screen Replacement, Battery: adım 1, 3 resimden 2. Dell Latitude ST Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the back panel tab.
    • Press down on the tab to remove the panel.
  2. Dell Latitude ST Screen Replacement: adım 2, 3 resimden 1. Dell Latitude ST Screen Replacement: adım 2, 3 resimden 2. Dell Latitude ST Screen Replacement: adım 2, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove the four 6mm screws attaching the inside panel to the device.
  3. Dell Latitude ST Screen Replacement: adım 3, 3 resimden 1. Dell Latitude ST Screen Replacement: adım 3, 3 resimden 2. Dell Latitude ST Screen Replacement: adım 3, 3 resimden 3.
    • Use the blue plastic opening tool to push in the tab located on the backside of the device.
    • Slide the tool around the edges of the device to unsnap the tabs and pry the frame off.
  4. Dell Latitude ST Screen Replacement: adım 4, 3 resimden 1. Dell Latitude ST Screen Replacement: adım 4, 3 resimden 2. Dell Latitude ST Screen Replacement: adım 4, 3 resimden 3.
    • Remove the three 6mm Phillips #0 screws attaching the battery.
  5. Dell Latitude ST Screen Replacement: adım 5, 3 resimden 1. Dell Latitude ST Screen Replacement: adım 5, 3 resimden 2. Dell Latitude ST Screen Replacement: adım 5, 3 resimden 3.
    • Using your hands or a plastic opening tool, unplug the white battery cable.
    • Push forward on the top part of the cable to disconnect it from the device.
  6. Dell Latitude ST Screen Replacement: adım 6, 3 resimden 1. Dell Latitude ST Screen Replacement: adım 6, 3 resimden 2. Dell Latitude ST Screen Replacement: adım 6, 3 resimden 3.
    • Pull up on the black tab located at the top of the battery to remove the battery from the device.
  7. Dell Latitude ST Screen Replacement, Screen: adım 7, 3 resimden 1. Dell Latitude ST Screen Replacement, Screen: adım 7, 3 resimden 2. Dell Latitude ST Screen Replacement, Screen: adım 7, 3 resimden 3.
    • Pull up on the copper antenna tape to loosen it from the base.
    • Unscrew the seven 6mm Phillips #0 screws from the base.
  8. Dell Latitude ST Screen Replacement: adım 8, 2 resimden 1. Dell Latitude ST Screen Replacement: adım 8, 2 resimden 2.
    • Locate the grey LCD cable attached to the motherboad on the device.
    • Pull up on the black tape handle attached to the LCD cable to disconnect the cable.
    • Be sure to pull on the back rather than the LCD cable itself.
  9. Dell Latitude ST Screen Replacement: adım 9, 3 resimden 1. Dell Latitude ST Screen Replacement: adım 9, 3 resimden 2. Dell Latitude ST Screen Replacement: adım 9, 3 resimden 3.
    • Using your hands or the blue plastic opening tool, go along the edges of the frame and unsnap the screen from the middle frame.
    • Lift the middle frame away from the screen.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 455
