Ana içeriğe geç
Dell Latitude X300 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Latitude X300 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
  2. Dell Latitude X300 Keyboard Replacement: adım 2, 2 resimden 1. Dell Latitude X300 Keyboard Replacement: adım 2, 2 resimden 2.
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  3. Dell Latitude X300 Keyboard Replacement: adım 3, 1 resimden 1.
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  4. Dell Latitude X300 Keyboard Replacement: adım 4, 1 resimden 1.
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  5. Dell Latitude X300 Keyboard Replacement: adım 5, 1 resimden 1.
    • Remove the flexible ribbon from the ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
Sonuç
Jacob Egorov
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-20, Maness Winter 2012 Cal Poly, Team 11-20, Maness Winter 2012 üyesi
CPSU-MANESS-W12S11G20
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 1,255
