Ana içeriğe geç
Dell Latitude X300 Latch Replacement
Neye ihtiyacın var
  1. Dell Latitude X300 Latch Replacement, Latch: adım 1, 1 resimden 1.
    • Make sure the power is off.
    • Remove the battery located on the bottom of the device by pushing in both clips.
  2. Dell Latitude X300 Latch Replacement: adım 2, 2 resimden 1. Dell Latitude X300 Latch Replacement: adım 2, 2 resimden 2.
    • Remove rubber caps on each corner of the front screen with a pinch.
    • Remove the 4 mm screws located on the front screen of the laptop.
  3. Dell Latitude X300 Latch Replacement: adım 3, 1 resimden 1.
    • Carefully, remove the screen casing using either your hands or a proper tool.
    • The casing is very flimsy, so use extreme care.
  4. Dell Latitude X300 Latch Replacement: adım 4, 1 resimden 1.
    • Remove the screws holding the latch in place.
    • Replace the old latch with the new one
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jacob
9 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014 üyesi
UMASSD-VIJAYBHASKAR-S14S6G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 341
