Giriş
Here is an older (2005) model Dell monitor. This one had a blinking green light. That is a common error for this model. The error is caused by either bad capacitors or two failed transistors, on the power supply board. For now, we are just looking into getting to the power supply.
Neye ihtiyacın var
Dell 174FPb with blinking power light
Here is the Dell Data sheet for this monitor.
Solid stand for this size monitor. It's the first thing to be removed.
Here is the LVDS cable
which disconnects by simply pulling up on the connector. The image is only to document that there is not tab or other locking mechanism on the connector. Do not pull on the wires to remove it.
Disconnect the CCFL connectors the same way. Pull on the actual connector, not the cable. No lock on the connectors, just a tight fit.
Here is the panel side of the chassis
Is the main board or Video board (AD board for some)
Power supply board
Remove the five (5) Philips head screws that hold the power supply board to the chassis.
Next remove the stopper for the AC connector. It's a bit tricky. Do no try to pry it out. It actually just slides up on the sheet metal.
This power supply indeed suffered form failed transistors. The ones that failed were Q759 and Q760. Both are 2SC5707 Bipolar transistors. Now, question of economics. The transistors are about $2 USD plus around $6 USD for shipping. That repair will leave us with a repaired power supply, but still only have a VGA connection on the monitor. I am leaning toward spending $25 USD for a universal LCD driver adapter. That will give this monitor HDMI and DVI connections, which will provide for more connectivity options. This might make the monitor more useful for another 10 years or so :-)
