Ana içeriğe geç
Dell Netbook e6400 keyboard Replacement
    1. Dell Netbook e6400  keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
      • remove battery
      FixBot'a Sor
      Yorum Ekle
    2. Dell Netbook e6400  keyboard Replacement: adım 2, 2 resimden 1. Dell Netbook e6400  keyboard Replacement: adım 2, 2 resimden 2.
      • Remove the card from the slots by pulling the tab
      • Levering on the plastic hooks, the upper line of keys that give access to the keyboard fixing screws is released at the front
      FixBot'a Sor
      Yorum Ekle
    3. Dell Netbook e6400  keyboard Replacement: adım 3, 1 resimden 1.
      • Pry underneath to extract the upper line of keys
      FixBot'a Sor
      Yorum Ekle
    4. Dell Netbook e6400  keyboard Replacement: adım 4, 3 resimden 1. Dell Netbook e6400  keyboard Replacement: adım 4, 3 resimden 2. Dell Netbook e6400  keyboard Replacement: adım 4, 3 resimden 3.
      • Unscrew the two Phillips screws that hold the keyboard attached to the notebook body
      • New line.itlick the black tab to pull back and to the other to unhook the keyboard
      FixBot'a Sor
      Yorum Ekle
Sonuç
to reassemble your device follow these instructions in reverse order
8 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
it en
100%
irlanda dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Smilzo
12.359 İtibar
39 adet Kılavuz yazıldı
2Kılavuz Yorumları
ciao and thanks for this guide @smilzo !
I recently had to re-seat the keyboard, which is a common trick for old Dell laptops when the keyboards starts having issues and types nonsense. However after putting it back together, the keyboard doesn’t light up anymore. what am I doing wrong? did I miss a connector?
alfx - Yanıt Paylaş
hi, sorry for what happened, try to disassemble the keyboard again and check that the connectors are inserted well on the correct side and that the cable has not broken.  good luck
Smilzo - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 2,234
