Ana içeriğe geç
Dell OptiPlex 9010 CPU Fan Replacement
Neye ihtiyacın var
  1. Dell OptiPlex 9010 CPU Fan Replacement, CPU Fan: adım 1, 3 resimden 1. Dell OptiPlex 9010 CPU Fan Replacement, CPU Fan: adım 1, 3 resimden 2. Dell OptiPlex 9010 CPU Fan Replacement, CPU Fan: adım 1, 3 resimden 3.
    • Ensure the PC is physically unplugged before beginning any disassembly procedures!
    • Place the PC on a flat surface.
    • Turn the PC over so that the panel side faces upward.
  2. Dell OptiPlex 9010 CPU Fan Replacement: adım 2, 3 resimden 1. Dell OptiPlex 9010 CPU Fan Replacement: adım 2, 3 resimden 2. Dell OptiPlex 9010 CPU Fan Replacement: adım 2, 3 resimden 3.
    • Use your hand to lift the handle upward to access the hardware.
  3. Dell OptiPlex 9010 CPU Fan Replacement: adım 3, 2 resimden 1. Dell OptiPlex 9010 CPU Fan Replacement: adım 3, 2 resimden 2.
    • Locate the CPU fan
    • Locate the fan header
  4. Dell OptiPlex 9010 CPU Fan Replacement: adım 4, 3 resimden 1. Dell OptiPlex 9010 CPU Fan Replacement: adım 4, 3 resimden 2. Dell OptiPlex 9010 CPU Fan Replacement: adım 4, 3 resimden 3.
    • Unplug the fan header by pressing the little button and pulling upward.
  5. Dell OptiPlex 9010 CPU Fan Replacement: adım 5, 2 resimden 1. Dell OptiPlex 9010 CPU Fan Replacement: adım 5, 2 resimden 2.
    • Unscrew the 1.2 mm screw using a Phillips #1 screwdriver by turning it counterclockwise (left)
    • Repeat the second step for the other 3 screws
    • If necessary, apply downward pressure on the screwdriver while turning to ensure the screws are fully removed
  6. Dell OptiPlex 9010 CPU Fan Replacement: adım 6, 3 resimden 1. Dell OptiPlex 9010 CPU Fan Replacement: adım 6, 3 resimden 2. Dell OptiPlex 9010 CPU Fan Replacement: adım 6, 3 resimden 3.
    • After disconnecting the fan from the frame, carefully lift the fan up.
    • Be sure to store the screws safely, as they will be needed later on.
  7. Dell OptiPlex 9010 CPU Fan Replacement: adım 7, 3 resimden 1. Dell OptiPlex 9010 CPU Fan Replacement: adım 7, 3 resimden 2. Dell OptiPlex 9010 CPU Fan Replacement: adım 7, 3 resimden 3.
    • Take the fan you intend to insert into the computer.
    • Align the new fan over the four screws you previously removed.
    • Insert the new fan header into its socket.
  8. Dell OptiPlex 9010 CPU Fan Replacement: adım 8, 3 resimden 1. Dell OptiPlex 9010 CPU Fan Replacement: adım 8, 3 resimden 2. Dell OptiPlex 9010 CPU Fan Replacement: adım 8, 3 resimden 3.
    • Ensure the fan is correctly aligned with the four screw holes.
    • Place screws back in the holes
    • Tighten screws using the Phillips #1 screwdriver by turning it clockwise (right).
    • If needed, apply downward pressure on the screwdriver while turning to ensure the screws are securely tightened.
  9. Dell OptiPlex 9010 CPU Fan Replacement: adım 9, 3 resimden 1. Dell OptiPlex 9010 CPU Fan Replacement: adım 9, 3 resimden 2. Dell OptiPlex 9010 CPU Fan Replacement: adım 9, 3 resimden 3.
    • The replacement of the Dell Optiplex 9010 Fan has been complete!
    • Place the access panel back on to secure the inner hardware.
Sonuç
You have successfully replaced the CPU Fan of your Dell Optiplex 9010!
Bir başkası bu kılavuzu tamamladı.
Abhiraj Khinda
196 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 41
Her zaman: 238
