Ana içeriğe geç
Dell OptiPlex FX170 Memory Board Replacement
Neye ihtiyacın var
  1. Dell OptiPlex FX170 Memory Board Replacement, Case: adım 1, 1 resimden 1.
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
  2. Dell OptiPlex FX170 Memory Board Replacement: adım 2, 2 resimden 1. Dell OptiPlex FX170 Memory Board Replacement: adım 2, 2 resimden 2.
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  3. Dell OptiPlex FX170 Memory Board Replacement: adım 3, 3 resimden 1. Dell OptiPlex FX170 Memory Board Replacement: adım 3, 3 resimden 2. Dell OptiPlex FX170 Memory Board Replacement: adım 3, 3 resimden 3.
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
  4. Dell OptiPlex FX170 Memory Board Replacement: adım 4, 2 resimden 1. Dell OptiPlex FX170 Memory Board Replacement: adım 4, 2 resimden 2.
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
  5. Dell OptiPlex FX170 Memory Board Replacement, Memory Board: adım 5, 1 resimden 1.
    • Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 1,497
