Giriş
The motherboard replacement for the OptiPlex FX170, compared to other computers, is actually rather painless. One should, however, be familiar with preventing electro-static dischage (ESD) damage to electronics.
Neye ihtiyacın var
With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
Pull the base stand straight up from the device.
Using fingers, push the clips on either side of the RAM. The RAM will pop up at a 45 degree angle when both clips are disengaged.
Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
To remove the battery, pull up on the connector that is plugged into the motherboard.
Remove the two 4mm Phillips #00 screws that are along the back of the case.
Gently grasp the motherboard by the heat sink (the black finned piece). Lift the motherboard at an angle such that the ports along the back side come up first.
Continue lifting the motherboard, then slowly tilt the piece off to the right to break the Mylar tape over the front USB ports.
