Ana içeriğe geç
Dell OptiPlex FX170 RAM Replacement
Neye ihtiyacın var
  1. Dell OptiPlex FX170 RAM  Replacement, Case: adım 1, 1 resimden 1.
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
    FixBot'a Sor
    Yorum Ekle
  2. Dell OptiPlex FX170 RAM  Replacement: adım 2, 2 resimden 1. Dell OptiPlex FX170 RAM  Replacement: adım 2, 2 resimden 2.
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Dell OptiPlex FX170 RAM  Replacement: adım 3, 3 resimden 1. Dell OptiPlex FX170 RAM  Replacement: adım 3, 3 resimden 2. Dell OptiPlex FX170 RAM  Replacement: adım 3, 3 resimden 3.
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
    FixBot'a Sor
    Yorum Ekle
  4. Dell OptiPlex FX170 RAM  Replacement: adım 4, 2 resimden 1. Dell OptiPlex FX170 RAM  Replacement: adım 4, 2 resimden 2.
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
    FixBot'a Sor
    Yorum Ekle
  5. Dell OptiPlex FX170 RAM  Replacement, RAM: adım 5, 2 resimden 1. Dell OptiPlex FX170 RAM  Replacement, RAM: adım 5, 2 resimden 2.
    • Using fingers, push the clips on either side of the RAM. The RAM will pop up at a 45 degree angle when both clips are disengaged.
    FixBot'a Sor
    Yorum Ekle
  6. Dell OptiPlex FX170 RAM  Replacement: adım 6, 1 resimden 1.
    • Lift and pull out the RAM.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 36
Her zaman: 1,733
