Ana içeriğe geç
Dell OptiPlex GX260 Case Replacement
Neye ihtiyacın var
  1. Dell OptiPlex GX260 Case Replacement, Case: adım 1, 2 resimden 1. Dell OptiPlex GX260 Case Replacement, Case: adım 1, 2 resimden 2.
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
Sonuç
To close the case, simply press it closed until you hear the tabs click into place.
18 farklı kişi bu kılavuzu tamamladı.
Kevin Schapansky
1.478 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G48
4 Üyeler
27 adet Kılavuz yazıldı
Bir Yorum
Thanks, couldn’t for the life of me figure out how to open the silly thing. :)
technojunkie_1999 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 46
Her zaman: 19,009
