Ana içeriğe geç
Dell OptiPlex GX260 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell OptiPlex GX260 Hard Drive Replacement, Case: adım 1, 2 resimden 1. Dell OptiPlex GX260 Hard Drive Replacement, Case: adım 1, 2 resimden 2.
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 1. Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 2. Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 3.
    • Identify the Hard Drive in the case.
    • If there is more than one hard drive installed the process is the same for each hard drive.
    • Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
    • Remove the IDE cable from the hard drive by gently pulling the ribbon cable out.
  3. Dell OptiPlex GX260 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Pinch the two green tabs inwards to release the hard drive and lift it out.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Kevin Schapansky
1.457 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G48
4 Üyeler
27 adet Kılavuz yazıldı
Bir Yorum
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Also, want to add another HD....but, there are no cables at all?
Elvis 1357 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 20
Her zaman: 18,753
