Ana içeriğe geç
Dell OptiPlex GX260 Main Fan Replacement
Neye ihtiyacın var
  1. Dell OptiPlex GX260 Main Fan Replacement, Case: adım 1, 2 resimden 1. Dell OptiPlex GX260 Main Fan Replacement, Case: adım 1, 2 resimden 2.
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Main Fan Replacement, Main Fan: adım 2, 2 resimden 1. Dell OptiPlex GX260 Main Fan Replacement, Main Fan: adım 2, 2 resimden 2.
    • Disconnect the fan cable from the motherboard.
  3. Dell OptiPlex GX260 Main Fan Replacement: adım 3, 3 resimden 1. Dell OptiPlex GX260 Main Fan Replacement: adım 3, 3 resimden 2. Dell OptiPlex GX260 Main Fan Replacement: adım 3, 3 resimden 3.
    • On the rear of the desktop, push the two circled black buttons straight in with a small pointed object while pulling up on the fan.
    • Once the fan is released, lift it straight up and out of the case.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Kevin Schapansky
1.478 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G48
4 Üyeler
27 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 8,076
