Ana içeriğe geç
Dell OptiPlex GX260 Optical Drive Replacement
Neye ihtiyacın var
  1. Dell OptiPlex GX260 Optical Drive Replacement, Case: adım 1, 2 resimden 1. Dell OptiPlex GX260 Optical Drive Replacement, Case: adım 1, 2 resimden 2.
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: adım 2, 3 resimden 1. Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: adım 2, 3 resimden 2. Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: adım 2, 3 resimden 3.
    • Identify the optical drive in the case.
    • Remove the analog audio cable from the optical drive.
    • Remove the IDE cable form the optical drive by pulling straight up on the orange plastic tab..
    • Remove the power cable from the optical drive.
  3. Dell OptiPlex GX260 Optical Drive Replacement: adım 3, 1 resimden 1.
    • Push the two green tabs toward each other to release the optical drive and lift it out.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Kevin Schapansky
1.478 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G48
4 Üyeler
27 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 8,950
