Ana içeriğe geç
Dell OptiPlex GX260 Power Supply Replacement
Neye ihtiyacın var
  1. Dell OptiPlex GX260 Power Supply Replacement, Case: adım 1, 2 resimden 1. Dell OptiPlex GX260 Power Supply Replacement, Case: adım 1, 2 resimden 2.
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Power Supply Replacement, Power Supply: adım 2, 1 resimden 1.
    • Locate the power supply in the case.
    • Disconnect the AXT power cable to the motherboard.
    • Disconnect the P4 12 volt power cable from the motherboard.
    • Disconnect the power cable from the optical drive.
    • Disconnect the floppy drive power cable.
    • Disconnect the hard drive power cable.
  3. Dell OptiPlex GX260 Power Supply Replacement: adım 3, 1 resimden 1.
    • Remove the two Phillip screws holding the power supply into the the case and lift the power supply out.
    • When installing a new power supply ensure that the voltage selector is correctly set before you connect the mains cable.
    • Incorrect voltage settings will damage the power supply and may also cause other components to be damaged.
  4. Dell OptiPlex GX260 Power Supply Replacement: adım 4, 1 resimden 1.
    • Push down on the green tab with one hand.
    • With your other hand, grip the top of the power supply and pull back and up to remove from the case.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Kevin Schapansky
1.478 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G48
4 Üyeler
27 adet Kılavuz yazıldı
Bir Yorum
In mine, the power supply was much longer due to a fan located on the front end. Same basic disassembly, however. There was a green tab at the front and it was difficult, but the power supply (with effort) did slide forward and out.
jknox - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 13,363
