Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This shows you how to replace a blown power supply on a Dell Optiplex 330 small form factor PC. Power supplies are normally the first part to go on a desktop and will result in a solid amber power light illuminated on a Dell desktop.
Neye ihtiyacın var
Before you can remove the power supply you first have to remove the optical drive.
First find the two cables going into the optical drive - they are shown in the first picture.
Gently pull both of them out - one of the cables might have a little latch that you have to press in order to release it from the optical drive.
You now need to remove the power cable connected to the motherboard.
Locate the large 24 pin power connecter - it is located next to the power supply. Carefully press down on the little latch and pull straight up to release.
Repeat this procedure for the little 4 pin connecter located between the processer and hard drive.
14 farklı kişi bu kılavuzu tamamladı.
