Ana içeriğe geç
Dell Optiplex 745 Motherboard Replacement
Neye ihtiyacın var
  1. Dell Optiplex 745 Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Dell Optiplex 745 Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Dell Optiplex 745 Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Orientate the computer so the case lock is on the left corner, like so.
    • Pull the tab that locks the casing in place.
    • While the tab is pulled, lift the casing off the computer.
  2. Dell Optiplex 745 Motherboard Replacement: adım 2, 3 resimden 1. Dell Optiplex 745 Motherboard Replacement: adım 2, 3 resimden 2. Dell Optiplex 745 Motherboard Replacement: adım 2, 3 resimden 3.
    • Lift the three tabs locking the face into place. (The plastic prying tool makes this easier.)
    • Pull the plastic face off of the computer.
  3. Dell Optiplex 745 Motherboard Replacement: adım 3, 3 resimden 1. Dell Optiplex 745 Motherboard Replacement: adım 3, 3 resimden 2. Dell Optiplex 745 Motherboard Replacement: adım 3, 3 resimden 3.
    • Pinch the two tabs locking the fan mount (annotated in a blue square).
    • Pull the mount up and out of the computer.
  4. Dell Optiplex 745 Motherboard Replacement: adım 4, 3 resimden 1. Dell Optiplex 745 Motherboard Replacement: adım 4, 3 resimden 2. Dell Optiplex 745 Motherboard Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Pull the orange connector out of the CD drive (annotated in an orange square).
    • Pull out the smaller connector (annotated in a black square). Tweezers make it easier but aren't required.
  5. Dell Optiplex 745 Motherboard Replacement: adım 5, 2 resimden 1. Dell Optiplex 745 Motherboard Replacement: adım 5, 2 resimden 2.
    • Pull the CD drive lock (annotated in blue) straight up.
    • While holding the lock up, pull out the CD drive.
  6. Dell Optiplex 745 Motherboard Replacement: adım 6, 3 resimden 1. Dell Optiplex 745 Motherboard Replacement: adım 6, 3 resimden 2. Dell Optiplex 745 Motherboard Replacement: adım 6, 3 resimden 3.
    • Unscrew the two screws (annotated with red circles) holding the GPU heatsync in place.
    • Swing it open then pull it straight up.
  7. Dell Optiplex 745 Motherboard Replacement: adım 7, 3 resimden 1. Dell Optiplex 745 Motherboard Replacement: adım 7, 3 resimden 2. Dell Optiplex 745 Motherboard Replacement: adım 7, 3 resimden 3.
    • Unscrew the two screws (annotated with a red circle).
    • Pull out the hinge for the GPU heatsync.
  8. Dell Optiplex 745 Motherboard Replacement: adım 8, 1 resimden 1.
    • Pull out the yellow and black connector that is connected to the Motherboard.
  9. Dell Optiplex 745 Motherboard Replacement: adım 9, 2 resimden 1. Dell Optiplex 745 Motherboard Replacement: adım 9, 2 resimden 2.
    • Pull out the large white power connector that is connected to the Motherboard.
    • Use the plastic prying tool to pull it up.
    • Alternate sides when prying until it comes loose.
  10. Dell Optiplex 745 Motherboard Replacement: adım 10, 3 resimden 1. Dell Optiplex 745 Motherboard Replacement: adım 10, 3 resimden 2. Dell Optiplex 745 Motherboard Replacement: adım 10, 3 resimden 3.
    • Unscrew the three screws (annotated in red).
    • Slide out the AC adapter.
    • If all the cables are detached, it should slide right out. If not, detach the remaining cables.
  11. Dell Optiplex 745 Motherboard Replacement: adım 11, 3 resimden 1. Dell Optiplex 745 Motherboard Replacement: adım 11, 3 resimden 2. Dell Optiplex 745 Motherboard Replacement: adım 11, 3 resimden 3.
    • Remove the blue wire connected to the Motherboard.
    • Remove the orange wire connected to the Motherboard.
    • Remove the wide grey connector from the Motherboard.
    • Use the yellow handle to pull it up.
  12. Dell Optiplex 745 Motherboard Replacement: adım 12, 2 resimden 1. Dell Optiplex 745 Motherboard Replacement: adım 12, 2 resimden 2.
    • Remove the last wire connected to the Motherboard.
    • Remove the grey wire connected to the fan.
  13. Dell Optiplex 745 Motherboard Replacement: adım 13, 3 resimden 1. Dell Optiplex 745 Motherboard Replacement: adım 13, 3 resimden 2. Dell Optiplex 745 Motherboard Replacement: adım 13, 3 resimden 3.
    • Unscrew the two screws holding the Motherboard down (annotated with the red circles).
  14. Dell Optiplex 745 Motherboard Replacement: adım 14, 2 resimden 1. Dell Optiplex 745 Motherboard Replacement: adım 14, 2 resimden 2.
    • Carefully lift the right side of the Motherboard.
    • After lifting it above the fan, pull it to the right to remove the Motherboard.
  15. Dell Optiplex 745 Motherboard Replacement: adım 15, 3 resimden 1. Dell Optiplex 745 Motherboard Replacement: adım 15, 3 resimden 2. Dell Optiplex 745 Motherboard Replacement: adım 15, 3 resimden 3.
    • Starting with the left side, insert the new Motherboard.
    • Once the ports are lined up, set down the right side of the Motherboard.
    • Then screw it back in and reassemble.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thank you and your contributors for providing this guide. I did not replace motherboard but three 2200 u capacitors on it. The thing works again!
Antti Huhtala - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 76
Her zaman: 4,769
