Ana içeriğe geç
Dell Optiplex 745 Small Form Factor Motherboard Replacement
Neye ihtiyacın var
  1. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Opening the case: adım 1, 2 resimden 1. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Opening the case: adım 1, 2 resimden 2.
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Motherboard Replacement: adım 2, 2 resimden 1. Dell Optiplex 745 Small Form Factor Motherboard Replacement: adım 2, 2 resimden 2.
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: adım 3, 3 resimden 1. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: adım 3, 3 resimden 2. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: adım 3, 3 resimden 3.
    • Disconnect all of the cords that are connected to the motherboard.
    • Press in the lever on the side of the male end, and then pull out.
    • Pull cord straight out.
    • Disconnect the front plate (USB and audio output) from the motherboard.
    • Some of the cords in the pictures are missing due to the condition of our device when creating this guide.
  4. Dell Optiplex 745 Small Form Factor Motherboard Replacement: adım 4, 3 resimden 1. Dell Optiplex 745 Small Form Factor Motherboard Replacement: adım 4, 3 resimden 2. Dell Optiplex 745 Small Form Factor Motherboard Replacement: adım 4, 3 resimden 3.
    • Remove the graphics card.
    • Lift the blue latch on the fat end of the graphics card.
    • Pull the blue lever on the skinny end of the graphics card toward the power supply.
    • Pull out one end of the card at a time.
  5. Dell Optiplex 745 Small Form Factor Motherboard Replacement: adım 5, 3 resimden 1. Dell Optiplex 745 Small Form Factor Motherboard Replacement: adım 5, 3 resimden 2. Dell Optiplex 745 Small Form Factor Motherboard Replacement: adım 5, 3 resimden 3.
    • Remove the heat sink.
    • Unscrew the (2) two screws using a Phillips #2 screwdriver and lift out the heat sink.
  6. Dell Optiplex 745 Small Form Factor Motherboard Replacement: adım 6, 3 resimden 1. Dell Optiplex 745 Small Form Factor Motherboard Replacement: adım 6, 3 resimden 2. Dell Optiplex 745 Small Form Factor Motherboard Replacement: adım 6, 3 resimden 3.
    • Remove the (5) five 6mm Phillips #2 screws from the motherboard.
    • Remove the (2) two 17mm Phillips #2 screws from the mount for the heat sink.
  7. Dell Optiplex 745 Small Form Factor Motherboard Replacement: adım 7, 3 resimden 1. Dell Optiplex 745 Small Form Factor Motherboard Replacement: adım 7, 3 resimden 2. Dell Optiplex 745 Small Form Factor Motherboard Replacement: adım 7, 3 resimden 3.
    • Remove the back plate by lifting straight out by the blue latch that secures the graphics card.
    • Pull the end of the motherboard closest to the back of the computer away from the static back plate.
    • Lift this end away and out of the case.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Alexander Rosner
291 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G5, Walkup Fall 2017 USF Tampa, Team S5-G5, Walkup Fall 2017 üyesi
USFT-WALKUP-F17S5G5
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 1,964
