Ana içeriğe geç
Dell Optiplex 745 Small Form Factor Power Supply Replacement
Neye ihtiyacın var
  1. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Opening the case: adım 1, 2 resimden 1. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Opening the case: adım 1, 2 resimden 2.
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Power Supply Replacement: adım 2, 2 resimden 1. Dell Optiplex 745 Small Form Factor Power Supply Replacement: adım 2, 2 resimden 2.
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Remove the Power Supply from the Case: adım 3, 2 resimden 1. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Remove the Power Supply from the Case: adım 3, 2 resimden 2.
    • Identify the power supply.
    • Remove the two 9.5 mm Phillips screws on the outside of the case.
  4. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Disconnect the power supply cables: adım 4, 2 resimden 1. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Disconnect the power supply cables: adım 4, 2 resimden 2.
    • Grab the plastic casing and pull out the bundle of cables from the side of the power supply unit.
  5. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Remove the power supply: adım 5, 1 resimden 1.
    • Push the power supply from the back and lift from the front.
    • Lift the power supply out of the case.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Samantha Hsu
416 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 13-10, Forte Fall 2014 Cal Poly, Team 13-10, Forte Fall 2014 üyesi
CPSU-FORTE-F14S13G10
6 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
good, but that's not the SFF model.
99mmarriott99 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 31
Her zaman: 6,606
