Ana içeriğe geç
Dell Optiplex 745 Small Form Factor Processor Replacement
Neye ihtiyacın var
  1. Dell Optiplex 745 Small Form Factor Processor Replacement, Opening the case: adım 1, 2 resimden 1. Dell Optiplex 745 Small Form Factor Processor Replacement, Opening the case: adım 1, 2 resimden 2.
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Processor Replacement: adım 2, 2 resimden 1. Dell Optiplex 745 Small Form Factor Processor Replacement: adım 2, 2 resimden 2.
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Processor Replacement, Processor: adım 3, 1 resimden 1.
    • The processor is located inside the heat sink (indicated by the marker).
  4. Dell Optiplex 745 Small Form Factor Processor Replacement: adım 4, 3 resimden 1. Dell Optiplex 745 Small Form Factor Processor Replacement: adım 4, 3 resimden 2. Dell Optiplex 745 Small Form Factor Processor Replacement: adım 4, 3 resimden 3.
    • Unscrew the 9.5 mm screws from heatsink on both sides using the Phillips #2 screwdriver.
    • If the processor is glued on to the heat sink, gently scrape off the glue and detach it from the device.
  5. Dell Optiplex 745 Small Form Factor Processor Replacement: adım 5, 3 resimden 1. Dell Optiplex 745 Small Form Factor Processor Replacement: adım 5, 3 resimden 2. Dell Optiplex 745 Small Form Factor Processor Replacement: adım 5, 3 resimden 3.
    • Push the small lever downwards, then sideways and upwards, in order to release it from the hook.
    • Remove the processor from its casing.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Abdullah Khan
181 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G5, Walkup Fall 2017 USF Tampa, Team S5-G5, Walkup Fall 2017 üyesi
USFT-WALKUP-F17S5G5
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 1,196
