Ana içeriğe geç
Dell Optiplex 745 Ultra Small Form Factor CPU Replacement
Neye ihtiyacın var
  1. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, Side Panel: adım 1, 1 resimden 1.
    • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: adım 2, 1 resimden 1.
    • Lay the computer on its side; you will see a blue knob.
    • Turn said knob 90 degrees counter clockwise.
  3. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: adım 3, 1 resimden 1.
    • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
  4. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: adım 4, 2 resimden 1. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: adım 4, 2 resimden 2.
    • Remove the blue shield by sliding it straight upwards.
  5. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: adım 5, 3 resimden 1. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: adım 5, 3 resimden 2. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: adım 5, 3 resimden 3.
    • Pull back on the tab nearest to the front case fan.
    • Slide the CPU heat sink from under the clip and pull upward.
    • You may need to twist the CPU heat sink side to side to free it from the thermal paste.
  6. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: adım 6, 2 resimden 1. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: adım 6, 2 resimden 2.
    • Ground yourself before removing any internal components.
    • Push release lever down slightly and away from CPU.
  7. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: adım 7, 2 resimden 1. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: adım 7, 2 resimden 2.
    • Lift and rotate processor cover off of CPU.
    • Processor cover will remain attached.
  8. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: adım 8, 1 resimden 1.
    • Using two fingers holding the sides, lift the CPU from the socket.
    • Do not touch the underside of the CPU or any of the pins.
    • When replacing the CPU, do not use excessive force.
    • Ensure to use the alignment-notches on the new CPU, when replacing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
donnavon
707 İtibar
7 adet Kılavuz yazıldı
Ekip
Pasco Hernando, Team 1-1, Prince Fall 2014 Pasco Hernando, Team 1-1, Prince Fall 2014 üyesi
PHSC-PRINCE-F14S1G1
11 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
What Cpu does it use?
Jazelle Estrada - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 2,153
