Ana içeriğe geç
Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement
  1. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement, Side Panel: adım 1, 1 resimden 1.
    • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement: adım 2, 1 resimden 1.
    • Lay the computer on its side; you will see a blue knob.
    • Turn said knob 90 degrees counter clockwise.
  3. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement: adım 3, 1 resimden 1.
    • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
  4. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Ground yourself to avoid static from damaging any components. Either use a wrist strap and antistatic mat, or touch the metal computer case every few minutes.
    • Find the power and data cables connected to the hard drive, press down on the metal tab and carefully remove them.
  5. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement: adım 5, 2 resimden 1. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement: adım 5, 2 resimden 2.
    • Locate the blue tabs shown on the left and right of the hard disk drive
    • Squeeze both tabs and slide the hard disk drive towards you, then lift the drive out of the cage.
Sonuç
donnavon
707 İtibar
7 adet Kılavuz yazıldı
Ekip
Pasco Hernando, Team 1-1, Prince Fall 2014 Pasco Hernando, Team 1-1, Prince Fall 2014 üyesi
PHSC-PRINCE-F14S1G1
11 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
I need of one this..+966551432137 WhatsApp
Luke Zoie - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 1,554
