Ana içeriğe geç
Dell Optiplex GX620 Hard Drive
Neye ihtiyacın var
  1. Dell Optiplex GX620 Hard Drive, How to unplug and discharge before repair: adım 1, 2 resimden 1. Dell Optiplex GX620 Hard Drive, How to unplug and discharge before repair: adım 1, 2 resimden 2.
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Hard Drive: adım 2, 2 resimden 1. Dell Optiplex GX620 Hard Drive: adım 2, 2 resimden 2.
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Hard Drive, Dell Optiplex GX620 Side Panel Disassembly: adım 3, 1 resimden 1.
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Hard Drive, Disconnect hard drive.: adım 4, 3 resimden 1. Dell Optiplex GX620 Hard Drive, Disconnect hard drive.: adım 4, 3 resimden 2. Dell Optiplex GX620 Hard Drive, Disconnect hard drive.: adım 4, 3 resimden 3.
    • Remove the power and SATA data cables.
    • SATA power
    • SATA data
  5. Dell Optiplex GX620 Hard Drive, Take hard drive out of the slot.: adım 5, 3 resimden 1. Dell Optiplex GX620 Hard Drive, Take hard drive out of the slot.: adım 5, 3 resimden 2. Dell Optiplex GX620 Hard Drive, Take hard drive out of the slot.: adım 5, 3 resimden 3.
    • Pull the two tabs on the hard drive and pull up
  6. Dell Optiplex GX620 Hard Drive, Remove hard drive from slot enclosure.: adım 6, 3 resimden 1. Dell Optiplex GX620 Hard Drive, Remove hard drive from slot enclosure.: adım 6, 3 resimden 2. Dell Optiplex GX620 Hard Drive, Remove hard drive from slot enclosure.: adım 6, 3 resimden 3.
    • Now take the tray off of the hard drive.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Padraic Hoselton
4.339 İtibar
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 38
Her zaman: 2,667
