Giriş
You should never try to repair a power supply unit. These are appropriately labeled, "Field Replaceable Units" for a reason. Disassembling a computer power supply unit can seriously harm and even kill you.
  1. Power down your PC and remove the power cord from the back. Power down your PC and remove the power cord from the back.
    • Power down your PC and remove the power cord from the back.
  2. Press and hold the power button for about 10 seconds, then release. This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
    • Press and hold the power button for about 10 seconds, then release.
      • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. With the computer standing upright, firmly pull on the tab at the back of the computer.
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Gently disconnect the power cables from the motherboard and drives. Gently disconnect the power cables from the motherboard and drives. Gently disconnect the power cables from the motherboard and drives.
    • Gently disconnect the power cables from the motherboard and drives.
  6. Remove the four screws that attach the power supply on the back of the chassis.
    • Remove the four screws that attach the power supply on the back of the chassis.
    • Do not remove any screws that are not highlighted in red.
  7. Press the blue release button. This is located on the floor of the computer chassis right in front of the power supply.
    • Press the blue release button. This is located on the floor of the computer chassis right in front of the power supply.
  8. Remove the unconnected power supply by sliding it towards the front of the computer. Next, lift it up out of the chassis.
    • Remove the unconnected power supply by sliding it towards the front of the computer. Next, lift it up out of the chassis.
Sonuç
8 başka kişi bu kılavuzu tamamladı.
Kristina
144 İtibar
7 adet Kılavuz yazıldı
Takım
Pasco Hernando, Team 5-1, Prince Fall 2014 Pasco Hernando, Team 5-1, Prince Fall 2014 üyesi
PHSC-PRINCE-F14S5G1
10 Üyeler
8 adet Kılavuz yazıldı
3 Yorum
Thanks, I followed the instructions, the replacement of the power supply unit was more simple than I expected
George
geotech78 - Yanıt
i replaced that but not repair this
Muhammad Qasim - Yanıt
At post Madasanal TQ disk bijapur
sidaray - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 Gün: 10
Son 30 Gün: 46
Her zaman: 4,334
