Ana içeriğe geç
Dell Optiplex SX280 Battery Replacement
Neye ihtiyacın var
  1. Dell Optiplex SX280 Battery Replacement, Panel Cover: adım 1, 1 resimden 1.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Battery Replacement: adım 2, 2 resimden 1. Dell Optiplex SX280 Battery Replacement: adım 2, 2 resimden 2.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Battery Replacement: adım 3, 2 resimden 1. Dell Optiplex SX280 Battery Replacement: adım 3, 2 resimden 2.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Battery Replacement, Hard Drive: adım 4, 2 resimden 1. Dell Optiplex SX280 Battery Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Unplug the blue cable that connects the hard drive to the motherboard.
  5. Dell Optiplex SX280 Battery Replacement: adım 5, 2 resimden 1. Dell Optiplex SX280 Battery Replacement: adım 5, 2 resimden 2.
    • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  6. Dell Optiplex SX280 Battery Replacement: adım 6, 1 resimden 1.
    • Squeeze the release tabs on either side of the hard drive.
  7. Dell Optiplex SX280 Battery Replacement: adım 7, 2 resimden 1. Dell Optiplex SX280 Battery Replacement: adım 7, 2 resimden 2.
    • Slide the Hard Drive out while squeezing the tabs.
  8. Dell Optiplex SX280 Battery Replacement, Battery: adım 8, 1 resimden 1.
    • Under the hard drive, there is a circular, silver battery connected to the motherboard.
    • Use a spudger to gently pry the battery from the motherboard.
  9. Dell Optiplex SX280 Battery Replacement: adım 9, 1 resimden 1.
    • Lift the battery out of the motherboard.
  10. Dell Optiplex SX280 Battery Replacement: adım 10, 3 resimden 1. Dell Optiplex SX280 Battery Replacement: adım 10, 3 resimden 2. Dell Optiplex SX280 Battery Replacement: adım 10, 3 resimden 3.
    • Upon replacement, simply push the battery into the motherboard.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Tom
841 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G4
4 Üyeler
26 adet Kılavuz yazıldı
Bir Yorum
that particular battery holder looked hard to get out- no pop out lever, thought i’d break it gouging it out!
neverts “itchytastyurr” ennud - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 11,767
