Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Lay the computer on its side; you will see a blue knob.
Turn this knob 90 deg clockwise.
Slide the panel case forward about 1/2 inch while knob is turned.
Lift panel case off computer.
Unplug the blue cable that connects the hard drive to the motherboard.
Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
Squeeze the release tabs on either side of the hard drive.
Under the hard drive, there is a circular, silver battery connected to the motherboard.
Use a spudger to gently pry the battery from the motherboard.
Upon replacement, simply push the battery into the motherboard.
10 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
that particular battery holder looked hard to get out- no pop out lever, thought i’d break it gouging it out!
