Ana içeriğe geç
Dell Optiplex SX280 Heat Sink Replacement
    1. Dell Optiplex SX280 Heat Sink Replacement, Panel Cover: adım 1, 1 resimden 1.
      • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
      • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Optiplex SX280 Heat Sink Replacement: adım 2, 2 resimden 1. Dell Optiplex SX280 Heat Sink Replacement: adım 2, 2 resimden 2.
      • Lay the computer on its side; you will see a blue knob.
      • Turn this knob 90 deg clockwise.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Optiplex SX280 Heat Sink Replacement: adım 3, 2 resimden 1. Dell Optiplex SX280 Heat Sink Replacement: adım 3, 2 resimden 2.
      • Slide the panel case forward about 1/2 inch while knob is turned.
      • Lift panel case off computer.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Optiplex SX280 Heat Sink Replacement, Heat Sink: adım 4, 2 resimden 1. Dell Optiplex SX280 Heat Sink Replacement, Heat Sink: adım 4, 2 resimden 2.
      • Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Optiplex SX280 Heat Sink Replacement: adım 5, 2 resimden 1. Dell Optiplex SX280 Heat Sink Replacement: adım 5, 2 resimden 2.
      • Press down on the release tab above the heat sink.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Optiplex SX280 Heat Sink Replacement: adım 6, 2 resimden 1. Dell Optiplex SX280 Heat Sink Replacement: adım 6, 2 resimden 2.
      • Pull the heat sink out of the computer while pressing on the release tab.
      • When reassembling make sure to clean the processor and heat sink of all old thermal paste and apply new paste to the processor
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Tom
850 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G4
4 Üyeler
151 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 6,700
