Ana içeriğe geç
Dell Optiplex SX280 Lower Fan Replacement
Neye ihtiyacın var
  1. Dell Optiplex SX280 Lower Fan Replacement, Panel Cover: adım 1, 1 resimden 1.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Lower Fan Replacement: adım 2, 2 resimden 1. Dell Optiplex SX280 Lower Fan Replacement: adım 2, 2 resimden 2.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Lower Fan Replacement: adım 3, 2 resimden 1. Dell Optiplex SX280 Lower Fan Replacement: adım 3, 2 resimden 2.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Lower Fan Replacement, Lower Fan: adım 4, 2 resimden 1. Dell Optiplex SX280 Lower Fan Replacement, Lower Fan: adım 4, 2 resimden 2.
    • Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
  5. Dell Optiplex SX280 Lower Fan Replacement: adım 5, 1 resimden 1.
    • Remove the power supply by pressing the release tab. It is distinguished by the black, red, green, and yellow wires.
  6. Dell Optiplex SX280 Lower Fan Replacement: adım 6, 2 resimden 1. Dell Optiplex SX280 Lower Fan Replacement: adım 6, 2 resimden 2.
    • Remove the rubber grommets from the base of the fan. The iFixit Opening tool may be useful in this step.
  7. Dell Optiplex SX280 Lower Fan Replacement: adım 7, 2 resimden 1. Dell Optiplex SX280 Lower Fan Replacement: adım 7, 2 resimden 2.
    • Press on the blue release tab and remove the fan.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tom
841 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G4
4 Üyeler
26 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 4,185
