Ana içeriğe geç
Dell Optiplex SX280 RAM Replacement
  1. Dell Optiplex SX280 RAM Replacement, Panel Cover: adım 1, 1 resimden 1.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 RAM Replacement: adım 2, 2 resimden 1. Dell Optiplex SX280 RAM Replacement: adım 2, 2 resimden 2.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 RAM Replacement: adım 3, 2 resimden 1. Dell Optiplex SX280 RAM Replacement: adım 3, 2 resimden 2.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 RAM Replacement, RAM: adım 4, 1 resimden 1.
    • The RAM are the two green cards in the corner of the computer.
    • At each end of the card, there are two white clips securing the RAM to the Motherboard.
  5. Dell Optiplex SX280 RAM Replacement: adım 5, 2 resimden 1. Dell Optiplex SX280 RAM Replacement: adım 5, 2 resimden 2.
    • Push down both white clips with your thumbs until you hear a click.
    • The RAM cards can now be removed.
Sonuç
To reassemble your device, follow these instructions (steps 1-3) in reverse order.
8 farklı kişi bu kılavuzu tamamladı.
Wyatt
784 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G4
4 Üyeler
26 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 5,597
