Ana içeriğe geç
Dell Optiplex SX280 Upper Fan Replacement
Neye ihtiyacın var
    1. Dell Optiplex SX280 Upper Fan Replacement, Panel Cover: adım 1, 1 resimden 1.
      • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
      • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Optiplex SX280 Upper Fan Replacement: adım 2, 2 resimden 1. Dell Optiplex SX280 Upper Fan Replacement: adım 2, 2 resimden 2.
      • Lay the computer on its side; you will see a blue knob.
      • Turn this knob 90 deg clockwise.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Optiplex SX280 Upper Fan Replacement: adım 3, 2 resimden 1. Dell Optiplex SX280 Upper Fan Replacement: adım 3, 2 resimden 2.
      • Slide the panel case forward about 1/2 inch while knob is turned.
      • Lift panel case off computer.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Optiplex SX280 Upper Fan Replacement, Upper Fan: adım 4, 2 resimden 1. Dell Optiplex SX280 Upper Fan Replacement, Upper Fan: adım 4, 2 resimden 2.
      • Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Optiplex SX280 Upper Fan Replacement: adım 5, 2 resimden 1. Dell Optiplex SX280 Upper Fan Replacement: adım 5, 2 resimden 2.
      • Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Optiplex SX280 Upper Fan Replacement: adım 6, 2 resimden 1. Dell Optiplex SX280 Upper Fan Replacement: adım 6, 2 resimden 2.
      • Remove the rubber grommets from the base of the fan. A screwdriver or spudger may be useful.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Optiplex SX280 Upper Fan Replacement: adım 7, 1 resimden 1.
      • Pull the upper fan out of the computer.
      FixBot'a Sor
      Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Tom
850 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G4
4 Üyeler
112 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 34
Her zaman: 5,681
