Ana içeriğe geç
Dell Photo Printer 540 LCD Panel Replacement
Neye ihtiyacın var
  1. Dell Photo Printer 540 LCD Panel Replacement, Case: adım 1, 1 resimden 1.
    • Rotate the photo printer so that the bottom of the case faces upward.
  2. Dell Photo Printer 540 LCD Panel Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
  3. Dell Photo Printer 540 LCD Panel Replacement: adım 3, 1 resimden 1.
    • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
  4. Dell Photo Printer 540 LCD Panel Replacement: adım 4, 1 resimden 1.
    • Remove the back panel of the case by pulling directly back.
    • Some carefully applied force may be required to remove this part.
  5. Dell Photo Printer 540 LCD Panel Replacement: adım 5, 1 resimden 1.
    • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
  6. Dell Photo Printer 540 LCD Panel Replacement: adım 6, 2 resimden 1. Dell Photo Printer 540 LCD Panel Replacement: adım 6, 2 resimden 2.
    • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
    • Caution! The side panel is held in by tabs; don't break these.
  7. Dell Photo Printer 540 LCD Panel Replacement, Cooling Fan: adım 7, 1 resimden 1.
    • Carefully remove the inner components of the device by lifting the inner components up and out of the casing.
  8. Dell Photo Printer 540 LCD Panel Replacement: adım 8, 1 resimden 1.
    • Locate the red and black cable that is connecting the fan to the top of the logic board.
  9. Dell Photo Printer 540 LCD Panel Replacement: adım 9, 1 resimden 1.
    • Carefully, remove the red and black cable from the logic board by pulling gently in order to isolate the cooling fan from the device.
  10. Dell Photo Printer 540 LCD Panel Replacement, LCD Panel: adım 10, 1 resimden 1.
    • Locate the data ribbon that connects the LCD panel to the mother board.
    • Carefully unclip the ribbon from the mother board.
    • Separate top cover from bottom base and flip upright so that the LCD panel is facing up for the next step
  11. Dell Photo Printer 540 LCD Panel Replacement: adım 11, 2 resimden 1. Dell Photo Printer 540 LCD Panel Replacement: adım 11, 2 resimden 2.
    • Slide the LCD panel out and away from the printer case.
    • Hold bottom of LCD panel and lift the screen 70 degrees. Set the screen face down for the next step
  12. Dell Photo Printer 540 LCD Panel Replacement: adım 12, 1 resimden 1.
    • Use a Phillips 00 screwdriver to remove the four 5.4 mm screws behind where the LCD screen is.
  13. Dell Photo Printer 540 LCD Panel Replacement: adım 13, 1 resimden 1.
    • You can now separate the individual pieces from each other, allowing the screen to be accessible to replace.
Sonuç
Ashley Lopez
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-7, Forte Spring 2012 Cal Poly, Team 14-7, Forte Spring 2012 üyesi
CPSU-FORTE-S12S14G7
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 619
