Ana içeriğe geç
Dell Photo Printer 540 Memory Card Reader Replacement
Neye ihtiyacın var
    1. Dell Photo Printer 540 Memory Card Reader Replacement, Case: adım 1, 1 resimden 1.
      • Rotate the photo printer so that the bottom of the case faces upward.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Photo Printer 540 Memory Card Reader Replacement: adım 2, 1 resimden 1.
      • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Photo Printer 540 Memory Card Reader Replacement: adım 3, 1 resimden 1.
      • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Photo Printer 540 Memory Card Reader Replacement: adım 4, 1 resimden 1.
      • Remove the back panel of the case by pulling directly back.
      • Some carefully applied force may be required to remove this part.
      FixBot'a Sor
      Yorum Ekle
    5. Dell Photo Printer 540 Memory Card Reader Replacement: adım 5, 1 resimden 1.
      • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
      FixBot'a Sor
      Yorum Ekle
    6. Dell Photo Printer 540 Memory Card Reader Replacement: adım 6, 2 resimden 1. Dell Photo Printer 540 Memory Card Reader Replacement: adım 6, 2 resimden 2.
      • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
      • Caution! The side panel is held in by tabs; don't break these.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Photo Printer 540 Memory Card Reader Replacement, Cooling Fan: adım 7, 1 resimden 1.
      • Carefully remove the inner components of the device by lifting the inner components up and out of the casing.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Photo Printer 540 Memory Card Reader Replacement: adım 8, 1 resimden 1.
      • Locate the red and black cable that is connecting the fan to the top of the logic board.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Photo Printer 540 Memory Card Reader Replacement: adım 9, 1 resimden 1.
      • Carefully, remove the red and black cable from the logic board by pulling gently in order to isolate the cooling fan from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Photo Printer 540 Memory Card Reader Replacement, Mother Board: adım 10, 3 resimden 1. Dell Photo Printer 540 Memory Card Reader Replacement, Mother Board: adım 10, 3 resimden 2. Dell Photo Printer 540 Memory Card Reader Replacement, Mother Board: adım 10, 3 resimden 3.
      • Locate the data ribbon that connects the LCD panel to the mother board.
      • Loosen the fasteners next to the ribbon by carefully pushing them away from the white ribbon holder.
      • Once the fasteners are loosened the ribbon should easily slide away from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Photo Printer 540 Memory Card Reader Replacement: adım 11, 3 resimden 1. Dell Photo Printer 540 Memory Card Reader Replacement: adım 11, 3 resimden 2. Dell Photo Printer 540 Memory Card Reader Replacement: adım 11, 3 resimden 3.
      • Locate the clips with multi-colored wires that connect the motherboard to the printing unit.
      • Disconnect both of them by gently pulling them away from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Photo Printer 540 Memory Card Reader Replacement: adım 12, 3 resimden 1. Dell Photo Printer 540 Memory Card Reader Replacement: adım 12, 3 resimden 2. Dell Photo Printer 540 Memory Card Reader Replacement: adım 12, 3 resimden 3.
      • Locate the white ribbon that connects the motherboard to the printing feed.
      • Disconnect the ribbon by gently pulling the ribbon away from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Photo Printer 540 Memory Card Reader Replacement: adım 13, 2 resimden 1. Dell Photo Printer 540 Memory Card Reader Replacement: adım 13, 2 resimden 2.
      • The mother board has changed orientation. Notice the new orientation based on the white data ribbon we removed in the previous step.
      • Locate the black data ribbon that connects the mother board to the printing motors.
      • Disconnect it from the logic board, by gently pulling the wire away from the mother board.
      FixBot'a Sor
      Yorum Ekle
    5. Dell Photo Printer 540 Memory Card Reader Replacement: adım 14, 1 resimden 1.
      • Now unscrew the three screws 7.89mm (counter-clockwise) using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Dell Photo Printer 540 Memory Card Reader Replacement: adım 15, 1 resimden 1.
      • Once screws and ribbons are disconnected, you can pull mother board away from the printing unit.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Photo Printer 540 Memory Card Reader Replacement, Removal of the Control Panel Motherboard: adım 16, 1 resimden 1.
      • Gain access to the bottom of the top case with a thin horizontal control panel motherboard attached to the bottom.
      • Remove the front panel.
      • The dell top casing should now only have two sides.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Photo Printer 540 Memory Card Reader Replacement: adım 17, 2 resimden 1. Dell Photo Printer 540 Memory Card Reader Replacement: adım 17, 2 resimden 2.
      • Locate the four 7.85 mm screws attaching the control panel motherboard to the top face casing.
      • Use a Phillips Head #1 screw driver to remove the four highlighted screws.
      • NOTE: Make sure removal of front face plate is completed.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Photo Printer 540 Memory Card Reader Replacement: adım 18, 1 resimden 1.
      • Gently lift the horizontal control panel motherboard and square power switch board.
      • Completely detach the motherboard from the face casing.
      • NOTE: Leave the power switch control attached to the main control panel motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Photo Printer 540 Memory Card Reader Replacement, Memory Card Reader: adım 19, 2 resimden 1. Dell Photo Printer 540 Memory Card Reader Replacement, Memory Card Reader: adım 19, 2 resimden 2.
      • Locate the clear data ribbon with a blue tip that connects the memory card reader to the control panel motherboard
      • Disconnect the data ribbon and the memory card reader is now separated.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jonathan Mintz
11 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-7, Forte Spring 2012 Cal Poly, Team 14-7, Forte Spring 2012 üyesi
CPSU-FORTE-S12S14G7
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 1,221
