Ana içeriğe geç
Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement
Neye ihtiyacın var
  1. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement, Case: adım 1, 1 resimden 1.
    • Rotate the photo printer so that the bottom of the case faces upward.
  2. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
  3. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 3, 1 resimden 1.
    • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
  4. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the back panel of the case by pulling directly back.
    • Some carefully applied force may be required to remove this part.
  5. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 5, 1 resimden 1.
    • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
  6. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 6, 2 resimden 1. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 6, 2 resimden 2.
    • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
    • Caution! The side panel is held in by tabs; don't break these.
  7. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement, Cooling Fan: adım 7, 1 resimden 1.
    • Carefully remove the inner components of the device by lifting the inner components up and out of the casing.
  8. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 8, 1 resimden 1.
    • Locate the red and black cable that is connecting the fan to the top of the logic board.
  9. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 9, 1 resimden 1.
    • Carefully, remove the red and black cable from the logic board by pulling gently in order to isolate the cooling fan from the device.
  10. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement, Mother Board: adım 10, 3 resimden 1. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement, Mother Board: adım 10, 3 resimden 2. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement, Mother Board: adım 10, 3 resimden 3.
    • Locate the data ribbon that connects the LCD panel to the mother board.
    • Loosen the fasteners next to the ribbon by carefully pushing them away from the white ribbon holder.
    • Once the fasteners are loosened the ribbon should easily slide away from the motherboard.
  11. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 11, 3 resimden 1. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 11, 3 resimden 2. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 11, 3 resimden 3.
    • Locate the clips with multi-colored wires that connect the motherboard to the printing unit.
    • Disconnect both of them by gently pulling them away from the motherboard.
  12. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 12, 3 resimden 1. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 12, 3 resimden 2. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 12, 3 resimden 3.
    • Locate the white ribbon that connects the motherboard to the printing feed.
    • Disconnect the ribbon by gently pulling the ribbon away from the motherboard.
  13. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 13, 2 resimden 1. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 13, 2 resimden 2.
    • The mother board has changed orientation. Notice the new orientation based on the white data ribbon we removed in the previous step.
    • Locate the black data ribbon that connects the mother board to the printing motors.
    • Disconnect it from the logic board, by gently pulling the wire away from the mother board.
  14. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 14, 1 resimden 1.
    • Now unscrew the three screws 7.89mm (counter-clockwise) using a Phillips #1 screwdriver.
  15. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 15, 1 resimden 1.
    • Once screws and ribbons are disconnected, you can pull mother board away from the printing unit.
  16. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement, Removal of the Control Panel Motherboard: adım 16, 1 resimden 1.
    • Gain access to the bottom of the top case with a thin horizontal control panel motherboard attached to the bottom.
    • Remove the front panel.
    • The dell top casing should now only have two sides.
  17. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 17, 2 resimden 1. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 17, 2 resimden 2.
    • Locate the four 7.85 mm screws attaching the control panel motherboard to the top face casing.
    • Use a Phillips Head #1 screw driver to remove the four highlighted screws.
    • NOTE: Make sure removal of front face plate is completed.
  18. Dell Photo Printer 540 Removal of the Control Panel Motherboard Replacement: adım 18, 1 resimden 1.
    • Gently lift the horizontal control panel motherboard and square power switch board.
    • Completely detach the motherboard from the face casing.
    • NOTE: Leave the power switch control attached to the main control panel motherboard.
Sonuç
Kishan Patel
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-7, Forte Spring 2012 Cal Poly, Team 14-7, Forte Spring 2012 üyesi
CPSU-FORTE-S12S14G7
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 22
Son 30 gün: 61
Her zaman: 982
