Ana içeriğe geç
Dell Photo Printer 720 Encoder Strip Replacement
Neye ihtiyacın var
    1. Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: adım 1, 3 resimden 1. Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: adım 1, 3 resimden 2. Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: adım 1, 3 resimden 3.
      • Use a Phillips head #2 screwdriver to remove the 4 screws located on the bottom of the Dell Photo Printer 720.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Photo Printer 720 Encoder Strip Replacement: adım 2, 3 resimden 1. Dell Photo Printer 720 Encoder Strip Replacement: adım 2, 3 resimden 2. Dell Photo Printer 720 Encoder Strip Replacement: adım 2, 3 resimden 3.
      • Use a spudger to wedge between the cover and base of the printer (where the light grey and black portions meet).
      • Pry apart the light grey cover from the black base.
      • Gently flip the printer upright to its standard position and carefully lift off the cover.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Photo Printer 720 Encoder Strip Replacement: adım 3, 2 resimden 1. Dell Photo Printer 720 Encoder Strip Replacement: adım 3, 2 resimden 2.
      • Slide the ink cartridge from the right side to the middle left so it is out of the way.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Photo Printer 720 Encoder Strip Replacement: adım 4, 3 resimden 1. Dell Photo Printer 720 Encoder Strip Replacement: adım 4, 3 resimden 2. Dell Photo Printer 720 Encoder Strip Replacement: adım 4, 3 resimden 3.
      • Grab ahold of the encoder strip on the right side. Gently tug the strip outward and swing the end piece towards you to unhook the encoder from the prong.
      • Carefully unhook the opposite end of the encoder strip to full disconnect the part.
      • To replace new encoder strip, reattach each end to the hooks by reversing previous steps.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Megan Lawrence
534 İtibar
5 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 1,036
