Ana içeriğe geç
Dell Photo Printer 720 Encoder Strip Replacement
Neye ihtiyacın var
  1. Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: adım 1, 3 resimden 1. Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: adım 1, 3 resimden 2. Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: adım 1, 3 resimden 3.
    • Use a Phillips head #2 screwdriver to remove the 4 screws located on the bottom of the Dell Photo Printer 720.
  2. Dell Photo Printer 720 Encoder Strip Replacement: adım 2, 3 resimden 1. Dell Photo Printer 720 Encoder Strip Replacement: adım 2, 3 resimden 2. Dell Photo Printer 720 Encoder Strip Replacement: adım 2, 3 resimden 3.
    • Use a spudger to wedge between the cover and base of the printer (where the light grey and black portions meet).
    • Pry apart the light grey cover from the black base.
    • Gently flip the printer upright to its standard position and carefully lift off the cover.
  3. Dell Photo Printer 720 Encoder Strip Replacement: adım 3, 2 resimden 1. Dell Photo Printer 720 Encoder Strip Replacement: adım 3, 2 resimden 2.
    • Slide the ink cartridge from the right side to the middle left so it is out of the way.
  4. Dell Photo Printer 720 Encoder Strip Replacement: adım 4, 3 resimden 1. Dell Photo Printer 720 Encoder Strip Replacement: adım 4, 3 resimden 2. Dell Photo Printer 720 Encoder Strip Replacement: adım 4, 3 resimden 3.
    • Grab ahold of the encoder strip on the right side. Gently tug the strip outward and swing the end piece towards you to unhook the encoder from the prong.
    • Carefully unhook the opposite end of the encoder strip to full disconnect the part.
    • To replace new encoder strip, reattach each end to the hooks by reversing previous steps.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Megan Lawrence
534 İtibar
5 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 45
Her zaman: 818
