Ana içeriğe geç
Dell Precision 3510 WLAN Card Replacement
Neye ihtiyacın var
  1. Dell Precision 3510 WLAN Card Replacement, Battery: adım 1, 2 resimden 1. Dell Precision 3510 WLAN Card Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the computer over so that you are looking at the bottom.
    • Use a Phillips #000 screwdriver to remove the eight 6.5 mm screws from the base cover.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Precision 3510 WLAN Card Replacement: adım 2, 1 resimden 1.
    • Use the opening tool to carefully pry the base cover from the computer.
    • Remove the base cover from the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Precision 3510 WLAN Card Replacement: adım 3, 2 resimden 1. Dell Precision 3510 WLAN Card Replacement: adım 3, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove the two 5.5 mm screws from the battery.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Precision 3510 WLAN Card Replacement: adım 4, 2 resimden 1. Dell Precision 3510 WLAN Card Replacement: adım 4, 2 resimden 2.
    • Gently unplug the cable connected to the top of the battery.
    • Remove the battery from the laptop.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Precision 3510 WLAN Card Replacement, WLAN Card: adım 5, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the single 3 mm screw securing the metal bracket to the WLAN card.
    • Remove the metal bracket from the system board.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Precision 3510 WLAN Card Replacement: adım 6, 1 resimden 1.
    • Carefully detach the two cables that are connected to the WLAN card.
    FixBot'a Sor
    Yorum Ekle
  7. Dell Precision 3510 WLAN Card Replacement: adım 7, 1 resimden 1.
    • Remove the WLAN card from the system board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Makenna Patrick
643 İtibar
5 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 46-3, Johansen Fall 2025 Texas Tech, Team 46-3, Johansen Fall 2025 üyesi
TTU-JOHANSEN-F25S46G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 142
