Ana içeriğe geç
Dell Precision 5510 Fans Replacement
Neye ihtiyacın var
  1. Dell Precision 5510 Fans Replacement, Base Cover: adım 1, 1 resimden 1.
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Fans Replacement: adım 2, 1 resimden 1.
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Fans Replacement, Fans: adım 3, 2 resimden 1. Dell Precision 5510 Fans Replacement, Fans: adım 3, 2 resimden 2.
    • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
    • Each fan has one 3.7mm screw and one 4.65mm screw.
  4. Dell Precision 5510 Fans Replacement: adım 4, 2 resimden 1. Dell Precision 5510 Fans Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
    • Do not grab by the wires, grab by the white rectangular region.
  5. Dell Precision 5510 Fans Replacement: adım 5, 2 resimden 1. Dell Precision 5510 Fans Replacement: adım 5, 2 resimden 2.
    • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
Sonuç
Amelia Andrews
97 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Harley Spring 2022 IUPUI, Team 2-1, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S2G1
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 848
