Ana içeriğe geç
Dell Precision 5510 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Precision 5510 Keyboard Replacement, Base Cover: adım 1, 1 resimden 1.
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Keyboard Replacement: adım 2, 1 resimden 1.
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Keyboard Replacement, Fans: adım 3, 2 resimden 1. Dell Precision 5510 Keyboard Replacement, Fans: adım 3, 2 resimden 2.
    • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
    • Each fan has one 3.7mm screw and one 4.65mm screw.
  4. Dell Precision 5510 Keyboard Replacement: adım 4, 2 resimden 1. Dell Precision 5510 Keyboard Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
    • Do not grab by the wires, grab by the white rectangular region.
  5. Dell Precision 5510 Keyboard Replacement: adım 5, 2 resimden 1. Dell Precision 5510 Keyboard Replacement: adım 5, 2 resimden 2.
    • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
  6. Dell Precision 5510 Keyboard Replacement, Battery: adım 6, 2 resimden 1. Dell Precision 5510 Keyboard Replacement, Battery: adım 6, 2 resimden 2.
    • Unplug the connection that links the battery to the computer.
  7. Dell Precision 5510 Keyboard Replacement: adım 7, 2 resimden 1. Dell Precision 5510 Keyboard Replacement: adım 7, 2 resimden 2.
    • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
  8. Dell Precision 5510 Keyboard Replacement: adım 8, 2 resimden 1. Dell Precision 5510 Keyboard Replacement: adım 8, 2 resimden 2.
    • Carefully remove the battery from the computer.
  9. Dell Precision 5510 Keyboard Replacement, Keyboard: adım 9, 1 resimden 1.
    • Remove 6 screws to take off the heat sink.
  10. Dell Precision 5510 Keyboard Replacement: adım 10, 1 resimden 1.
    • Remove all standalone motherboard screws.
    • 8 screws with lengths of either 3.7mm or 4.65mm
  11. Dell Precision 5510 Keyboard Replacement: adım 11, 1 resimden 1.
    • Remove the motherboard.
  12. Dell Precision 5510 Keyboard Replacement: adım 12, 1 resimden 1.
    • Remove nine screws from the back of the keyboard.
    • Screws are 1.9mm in length
  13. Dell Precision 5510 Keyboard Replacement: adım 13, 1 resimden 1.
    • Pull keyboard out and replace.
Sonuç
Colin Hunter
121 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Harley Spring 2022 IUPUI, Team 2-1, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S2G1
4 Üyeler
4 adet Kılavuz yazıldı
1Rehber Yorum
Do you need to remove the heatsink? I don't see why it cant be left on.
Alexandru - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 56
Her zaman: 2,409
