Ana içeriğe geç
Dell Precision 5510 Screen Replacement
Neye ihtiyacın var
  1. Dell Precision 5510 Screen Replacement, Base Cover: adım 1, 1 resimden 1.
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Screen Replacement: adım 2, 1 resimden 1.
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Screen Replacement, Battery: adım 3, 2 resimden 1. Dell Precision 5510 Screen Replacement, Battery: adım 3, 2 resimden 2.
    • Unplug the connection that links the battery to the computer.
  4. Dell Precision 5510 Screen Replacement: adım 4, 2 resimden 1. Dell Precision 5510 Screen Replacement: adım 4, 2 resimden 2.
    • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
  5. Dell Precision 5510 Screen Replacement: adım 5, 2 resimden 1. Dell Precision 5510 Screen Replacement: adım 5, 2 resimden 2.
    • Carefully remove the battery from the computer.
  6. Dell Precision 5510 Screen Replacement, Screen: adım 6, 2 resimden 1. Dell Precision 5510 Screen Replacement, Screen: adım 6, 2 resimden 2.
    • Remove the six 4.0 mm Phillips #1 screws.
  7. Dell Precision 5510 Screen Replacement: adım 7, 2 resimden 1. Dell Precision 5510 Screen Replacement: adım 7, 2 resimden 2.
    • Unscrew the one 4.0 mm Phillips #1 screw from the WiFi chip, then remove it.
  8. Dell Precision 5510 Screen Replacement: adım 8, 2 resimden 1. Dell Precision 5510 Screen Replacement: adım 8, 2 resimden 2.
    • Disconnect the black wire. Use tweezers to help.
  9. Dell Precision 5510 Screen Replacement: adım 9, 2 resimden 1. Dell Precision 5510 Screen Replacement: adım 9, 2 resimden 2.
    • Disconnect the multi wire. Use tweezers to help.
  10. Dell Precision 5510 Screen Replacement: adım 10, 2 resimden 1. Dell Precision 5510 Screen Replacement: adım 10, 2 resimden 2.
    • Remove the 1.0 mm Phillips #1 screw.
  11. Dell Precision 5510 Screen Replacement: adım 11, 2 resimden 1. Dell Precision 5510 Screen Replacement: adım 11, 2 resimden 2.
    • Flip the laptop over, so it is sitting in the normal upright position. Hold onto the screen, and pull the keyboard up and away from the screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Atlanta Phelps
400 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G5, Arle Fall 2018 IUPUI, Team S1-G5, Arle Fall 2018 üyesi
IUPUI-ARLE-F18S1G5
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Can I just change the LCD? Or is changing the entire display assembly the only option?
John Gaines - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 30
Her zaman: 3,946
