Ana içeriğe geç
Dell Precision 5520 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Precision 5520 Hard Drive Replacement, Base Cover: adım 1, 2 resimden 1. Dell Precision 5520 Hard Drive Replacement, Base Cover: adım 1, 2 resimden 2.
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
  2. Dell Precision 5520 Hard Drive Replacement, Battery: adım 2, 1 resimden 1.
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
  3. Dell Precision 5520 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Remove the four M2x4 screws securing the hard-drive bracket to the computer [1].
    • Lift the hard-drive cage [2] off the hard drive assembly [3].
  4. Dell Precision 5520 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Disconnect the hard-drive cable from the system board [1].
    • Lift the hard drive off the palm rest assembly [2].
  5. Dell Precision 5520 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Disconnect the hard drive interposer from the hard drive assembly and then remove the hard drive covers away from the hard drive.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Johnathan Hammond
45.237 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 68
Her zaman: 7,994
