Ana içeriğe geç
Dell Precision 5520 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Precision 5520 Memory Module Replacement, Base Cover: adım 1, 2 resimden 1. Dell Precision 5520 Memory Module Replacement, Base Cover: adım 1, 2 resimden 2.
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Precision 5520 Memory Module Replacement, Battery: adım 2, 1 resimden 1.
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
    FixBot'a Sor
    Yorum Ekle
  3. Dell Precision 5520 Memory Module Replacement, Memory Module: adım 3, 1 resimden 1.
    • Pry the securing clips away from the memory module until it pops-up [1]. Then, remove the memory module from its connector on the system board [2].
    FixBot'a Sor
    Yorum Ekle
Sonuç
Johnathan Hammond
46.149 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.003 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 38
Her zaman: 1,804
