Ana içeriğe geç
Dell Precision 5540 Fans Replacement
Neye ihtiyacın var
    • Ensure that your work surface is flat and clean to prevent the computer cover from being scratched.
    • Turn off your computer.
    • Disconnect your computer from all the cables.
  1. Dell Precision 5540 Fans Replacement, Remove the base cover screws: adım 2, 2 resimden 1. Dell Precision 5540 Fans Replacement, Remove the base cover screws: adım 2, 2 resimden 2.
    • Close the display lid and turn the computer over.
    • Remove the M2x3 T5 screws that secure the base cover to the computer.
    • Turn the system badge flap over and then remove the M2x8.5 screws that secure the base cover to the computer.
  2. Dell Precision 5540 Fans Replacement, Remove the base cover: adım 3, 2 resimden 1. Dell Precision 5540 Fans Replacement, Remove the base cover: adım 3, 2 resimden 2.
    • Pry the edges of the base cover and lift it to remove it from the computer. Consider using a spudger.
    • Two case latches are approximately here.
  3. Dell Precision 5540 Fans Replacement, Remove battery plug: adım 4, 1 resimden 1.
    • Here.
    • There is a very small amount of space, so I didn't unplugged it fully, just removed from the socket. And made sure that there is no contact.
  4. Dell Precision 5540 Fans Replacement, Remove CPU fan: adım 5, 1 resimden 1.
    • Unplug the fan cord.
    • Note the dot on the fan power socket which mark the upper side.
    • Unscrew M2 screws.
  5. Dell Precision 5540 Fans Replacement, Remove GPU fan: adım 6, 1 resimden 1.
    • Unscrew M2 screws
Sonuç
Nick Panin
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 377
