Ana içeriğe geç
Dell Precision 7510 KeyBoard Replacement
Neye ihtiyacın var
  1. Dell Precision 7510 KeyBoard Replacement, Removing the Battery Cover: adım 1, 1 resimden 1.
    • Slide the release latch to unlock the battery cover.
    • Slide and lift the battery cover to remove it from the computer.
  2. Dell Precision 7510 KeyBoard Replacement, Removing the Battery Cover: adım 2, 1 resimden 1.
    This should be called "removing the battery", isn't it?
    ricky-fe - Yanıt
  3. Dell Precision 7510 KeyBoard Replacement, Removing the Hard Drive: adım 3, 1 resimden 1.
    • Remove the screws that secure the hard drive to the computer.
    • Lift the hard-drive latch to the unlock position.
    • Slide and lift the hard drive from the computer.
  4. Dell Precision 7510 KeyBoard Replacement, Remove the Screws: adım 4, 1 resimden 1.
    • Remove the screws that secure the hard drive. Lift the hard drive away from the bracket.
    Why is this necessary for replacing the keyboard?
    Nathan Gelderloos - Yanıt
    I'm gonna go on a limb here and say you can skip this step....
    Jonesy - Yanıt
  5. Dell Precision 7510 KeyBoard Replacement, Removing the Keyboard Cables: adım 5, 1 resimden 1.
    • Peel the tape to access the cable.
    • Lift the tab and disconnect the keyboard cables from the system board.
  6. Dell Precision 7510 KeyBoard Replacement, Removing the Keyboard: adım 6, 1 resimden 1.
    • Pry the keyboard trim starting from bottom and work along the top edge and remove it away from the computer.
    • Remove the screws that secure the keyboard to the computer.
    • Lift the front side and slide the keyboard to remove it away from the computer.
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Johnathan Hammond
45.237 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
1Rehber Yorum
Einfach und verständlich geschrieben. Habs ohne Probleme geschafft :-)
Nur hab ich mich gefragt: Wozu Schritt 4?! Der ist zum Entfernen der Tastatur gar nicht nötig.
Wer also nur die Tastatur wechseln möchte, kann von 3 gleich zu 5 springen.
Danke für die Anleitung.
Hat mir sehr geholfen.
f_siman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 31
Her zaman: 4,006
