Ana içeriğe geç
Dell Precision 7510 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: adım 1, 1 resimden 1.
    • Slide the release latch to unlock the battery cover.
    • Slide and lift the battery cover to remove it from the computer.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: adım 2, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Precision 7510 Memory Module Replacement, Removing the Hard Drive: adım 3, 1 resimden 1.
    • Remove the screws that secure the hard drive to the computer.
    • Lift the hard-drive latch to the unlock position.
    • Slide and lift the hard drive from the computer.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Precision 7510 Memory Module Replacement, Remove the Screws: adım 4, 1 resimden 1.
    • Remove the screws that secure the hard drive. Lift the hard drive away from the bracket.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard Cables: adım 5, 1 resimden 1.
    • Peel the tape to access the cable.
    • Lift the tab and disconnect the keyboard cables from the system board.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard: adım 6, 1 resimden 1.
    • Pry the keyboard trim starting from bottom and work along the top edge and remove it away from the computer.
    • Remove the screws that secure the keyboard to the computer.
    • Lift the front side and slide the keyboard to remove it away from the computer.
    FixBot'a Sor
    Yorum Ekle
  7. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: adım 7, 1 resimden 1.
    • Remove the screw that secures the memory shield to the computer.
    • Lift and remove the memory shield from the computer.
    • Pry the retention clips away from the memory module until it pops up.
    • Lift the memory module and remove it from the computer.
    FixBot'a Sor
    Yorum Ekle
  8. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: adım 8, 1 resimden 1.
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Johnathan Hammond
46.158 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.003 adet Kılavuz yazıldı
1Rehber Yorum
Thanks Johnathan. Step 4 is unnecessary.
Joseph R. Scandora - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 72
Her zaman: 12,019
