Ana içeriğe geç
Dell Precision 7560 Battery Replacement
Neye ihtiyacın var
  1. Dell Precision 7560 Battery Replacement, Battery: adım 1, 3 resimden 1. Dell Precision 7560 Battery Replacement, Battery: adım 1, 3 resimden 2. Dell Precision 7560 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Battery Replacement: adım 2, 3 resimden 1. Dell Precision 7560 Battery Replacement: adım 2, 3 resimden 2. Dell Precision 7560 Battery Replacement: adım 2, 3 resimden 3.
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Battery Replacement: adım 3, 3 resimden 1. Dell Precision 7560 Battery Replacement: adım 3, 3 resimden 2. Dell Precision 7560 Battery Replacement: adım 3, 3 resimden 3.
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Laisha
205 İtibar
2 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
Was able to reset a battery that stopped charging with these instructions, appreciate it!
Emiline Doerr - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 29
Son 30 gün: 139
Her zaman: 2,456
