Ana içeriğe geç
Dell Precision 7560 Fan Replacement
Neye ihtiyacın var
  1. Dell Precision 7560 Fan Replacement, Fan: adım 1, 2 resimden 1. Dell Precision 7560 Fan Replacement, Fan: adım 1, 2 resimden 2.
    • The screws holding the fan in place cannot be fully removed.
    • Loosen the eight captive screws that secure the fan assembly.
    • Each screw is numbered in the order that they should be loosened.
  2. Dell Precision 7560 Fan Replacement: adım 2, 2 resimden 1. Dell Precision 7560 Fan Replacement: adım 2, 2 resimden 2.
    • Locate connector cable and pull lightly to remove.
  3. Dell Precision 7560 Fan Replacement: adım 3, 2 resimden 1. Dell Precision 7560 Fan Replacement: adım 3, 2 resimden 2.
    • Gently pull the first fan connector from the head until it is removed.
    • The thin wire is prone to damage. Exercise extra caution during removal.
  4. Dell Precision 7560 Fan Replacement: adım 4, 2 resimden 1. Dell Precision 7560 Fan Replacement: adım 4, 2 resimden 2.
    • Gently pull the second fan connector from the head until it is removed.
  5. Dell Precision 7560 Fan Replacement: adım 5, 2 resimden 1. Dell Precision 7560 Fan Replacement: adım 5, 2 resimden 2.
    • Lifting from the bottom, carefully remove the laptop's fans.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jack Allred
345 İtibar
2 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 28
Son 30 gün: 115
Her zaman: 2,604
